wiring diagram for RR classic Vogue 93 SE
RE: wiring diagram for RR classic Vogue 93 SE
From One 1993 RRC owner to another...
http://www.landrover.ee/est/varia/downloads/cars.htm
IF this free-bee doesn't help then nothing else can. I paid $200 for the same version in print 10 years ago. Download them ALL today and save them -- 1995 and the 1987-1991 versions, who knows how long it will be out there....
Good Luck...
Good Luck...
We finally got the SWB sorted --
remove door panels and spray linkages with (1) penetrating oil and then (2) white lithium grease
Check for stiff - binding linkage on the doors, lube the push/pull door lock unit on the window edge near the back.
ensure linkage can't pop off on the push-pull.
took the alarm to a dealer who installed NEW chips in remotes+dash unit and reprogrammed it (amazingly it was $50 chips + $60 labor) -- fixed the remotes, alarm, and door locking. The battery was dead for a long time and the voltage spike killed the chip in the dash unit (in the US it is on the left, far left behind the vents. bent the antenna up into the air a bit more and it extended the range 2x.
webreka
03-25-2007 09:25 PM
