wiring diagram for RR classic Vogue 93 SE
Old Mar 7, 2008 | 02:37 PM
Rangerover 1993's Avatar
3rd Gear
Default wiring diagram for RR classic Vogue 93 SE
[:@] I have a severe electrical problem after the heater matrix blew up, I need a wiring diag for a 93 RR classic Vogue SE. all sorts of probs central locking, alarm, can anyone help please
Old Mar 7, 2008 | 07:08 PM
cold_surfer's Avatar
Default RE: wiring diagram for RR classic Vogue 93 SE
From One 1993 RRC owner to another...
http://www.landrover.ee/est/varia/downloads/cars.htm
IF this free-bee doesn't help then nothing else can. I paid $200 for the same version in print 10 years ago. Download them ALL today and save them -- 1995 and the 1987-1991 versions, who knows how long it will be out there....
Good Luck...
Old Mar 7, 2008 | 07:17 PM
We finally got the SWB sorted --
remove door panels and spray linkages with (1) penetrating oil and then (2) white lithium grease
Check for stiff - binding linkage on the doors, lube the push/pull door lock unit on the window edge near the back.
ensure linkage can't pop off on the push-pull.
took the alarm to a dealer who installed NEW chips in remotes+dash unit and reprogrammed it (amazingly it was $50 chips + $60 labor) -- fixed the remotes, alarm, and door locking. The battery was dead for a long time and the voltage spike killed the chip in the dash unit (in the US it is on the left, far left behind the vents. bent the antenna up into the air a bit more and it extended the range 2x.
samsly
Audio/Visual Electronics
Oct 27, 2008 02:30 PM
webreka
Mar 25, 2007 09:25 PM
alex of minnesota
Jan 9, 2007 05:14 PM
ljw101
Freelander
Jun 25, 2006 02:43 PM
saka24
Aug 11, 2005 07:19 PM
