Working on the front end
Old Nov 15, 2013 | 07:10 PM
Bassmaster's Avatar
Default Working on the front end
About to fix the shaking in the Range Rover. I believe it the stabilizer bar so I'm replacing the bushings on them. I will also be changing the u joints and tie rod ends and putting in the front prop shaft. Has anyone done this before and can give me so advice or heads up? Or anything else I should replace it look at too that might be causing the car to shake?
Old Nov 18, 2013 | 08:36 AM
drowssap's Avatar
You could replace all that and still have a vibration why not find the problem rather than replacing everything. On mine it was the tie rod end but I also put a new stabilizer on it.
Old Nov 18, 2013 | 06:04 PM
Bassmaster's Avatar
I haven't done much work with the front end, and can't for sure identify the problem. And might as well replace everything while its already a part
Old Nov 18, 2013 | 06:12 PM
04duxlr's Avatar
My P38 had wiped out ball joints at 134,000 miles and still didn't shake.
Checking the pieces is a good idea regardless. Just jack up one side and start pulling on the wheels to see if there is play anywhere. All there is up there are the 4 joints at the ends of the tierod and drag link, and the ball joints.
Old Nov 19, 2013 | 06:33 AM
drowssap's Avatar
if you cant find the problem yourself take it to an alignment shop, the first thing they should do is inspect all your frontend parts as it can not be proper aligned with worn parts. it will be the cheapest diagnosis you will get, as they will not be able to align it. if you pm me I can walk you thru checking it yourself .
Old Nov 19, 2013 | 04:03 PM
Bassmaster's Avatar
I'm going to work on it this weekend. I will pm you then. I jacked up the car before and felt no play in any of the wheels.
tsuyoi
Sep 22, 2020 10:37 AM
LRXD
Sep 22, 2005 01:27 AM
wax
Nov 20, 2004 05:32 PM
jvanbelkum
Nov 4, 2004 03:48 PM
