Sponsored by: CARiD
00 d2 stalling
Old Apr 4, 2015 | 01:51 PM
wshort1's Avatar
3rd Gear
Default 00 d2 stalling
I'm new to the rovor world I purchased a 2000 d2 used, the problem I'm having is that the vehicle randomly dies. Runs great and will just shut down, give it 15 20 minutes and it will restart. codes were p1590 abs know that one and p1884 a can code, any suggestions on were to look for the problem would be great, suspect the crank sensor, anybody ever run into this.
Old Apr 4, 2015 | 02:55 PM
dusty1's Avatar
Crank sensor is a good guess
But you really need a Land Rover specific reader to tell you what's going on with the ABS and with the 1884....otherwise they are pretty generic codes...iirc tps has something that falls under the 1884 sub
Old Apr 4, 2015 | 03:49 PM
wshort1's Avatar
3rd Gear
Thanks dusty1 and I see that there are a lot of subs under 1884, my problem is that I'm over an hour away from the dealer and when I called to talk to then they were pretty rude just would not help at all. So I'm kinda on my Owen here. Thanks though I do appreciate your help.
Old Apr 4, 2015 | 04:39 PM
drowssap's Avatar
Keep an OB2 SCANNER with you when it dies see if you have a live RPM reading while cranking, if not you need a new ckps
Old Apr 5, 2015 | 11:59 AM
wshort1's Avatar
3rd Gear
I will Thanks
greenoval
May 11, 2006 11:45 AM
MikeRover
Jun 25, 2005 04:34 PM
slamwhit
Jun 17, 2005 05:11 PM
trailhead4x4
May 25, 2005 08:48 PM
Bene
May 1, 2005 04:21 AM
