01 discovery will not start
Hello, it seems like you know what you're doing. I have an 01 Discovery with the v8 that I also got as a repo. I got it for a very good price but I knew that it didn't run. I never got a key with the truck so when I started trouble shooting I had to take the ignition apart to bypass the ignition lock. I have everything I need to get a key made but i don't want to spend the money if I don't have to yet. When I took it apart I was able to get it to turn over but no spark. I found a blown fuse in the inside box. Now I have spark but no fuel. I checked the inertia switch and it was fine. I tried jumping the relay but still nothing. I'm beginning to think I need a new pump but I don't know if the ignition switch needs to be turned for the pump to work. I would be grateful for any help you could give. I've spent a lot of time on this one. Thank you.
Is there any way to put power straight to the pump to see if it is bad? I testes the terminals where the relay plugs in, I first tested them with the ignition off and one of them had 12 v. I then turned the ignition on and no change. That one terminal had 12 v and the other three didn't really show anything.
dmatranga
02-05-2013 12:27 AM
Evan5291
07-26-2011 06:06 AM
