Sponsored by: CARiD
01 Range Rover Door Locks
Old Jun 28, 2006 | 02:40 PM
drpenaranda's Avatar
6th Gear
Default 01 Range Rover Door Locks
Have a 01 Range Rover with door locks that drive me crazy. When im driving they will lock and unlock constantly...I have heard that if you change the handles it will stop, but this will cost about $400 per handle. Is there any other way to take care of this issue????
Old Jun 28, 2006 | 02:57 PM
Default RE: 01 Range Rover Door Locks
You most likely have a bad door lock actuator, one that is slow to work, or only works oart way or sometimes. You need to find which one is bad and check out the actuator to see if it is out of alignment, needs greasing or going bad. Once you find the bad one and replace it, you should be fine.
Mike
Old Jun 29, 2006 | 03:23 AM
Bait's Avatar
ORIGINAL: drpenaranda
Not really. The door latch assemblies include everything. They are prone to water ingress. Driver's side and Passengers side both fail.
Lisa
Oct 17, 2005 10:00 PM
Lisa
Aug 20, 2005 11:16 AM
Lisa
Aug 8, 2005 10:31 PM
II2Go
May 30, 2005 08:31 PM
Kennydhl
Apr 18, 2005 10:54 PM
