Sponsored by: CARiD
02 disco ii. i need help
Old Apr 12, 2015 | 06:43 PM
rit1267's Avatar
Default 02 disco ii. i need help
I have an 02 disco ii. coils, plugs and wires have 3000 miles on them. last week i got a #3 cylinder misfire that cleared up in about 10 min. truck ran fine until today and im getting a #1 cylinder misfire. i have found that the throttle body heater/flange is leaking coolant onto the valve cover right above #1 and #3 and coolant is getting on the wires. 2 questions: could that coolant on plug wires be the cause of misfire and i live in a hot climate and am wondering if i can bypass the throttle body heater? please help
Old Apr 12, 2015 | 06:45 PM
dusty1's Avatar
Probably not the cause of your misfires, but you can bypass it with the horseshoe bend in a quarter inch piece of copper tubing
Old Apr 12, 2015 | 07:00 PM
rit1267's Avatar
thanks dusty. that is what i thought. i'll tell ya, i'm new to owning a disco and it is definitely a love/hate relationship.
Old Apr 12, 2015 | 08:08 PM
dusty1's Avatar
Doesn't take long to get familiar with it. Then it gets pretty simple.
I would expect to find some leaking injectors or something silly like that that might explain both issues
Old Apr 13, 2015 | 07:31 AM
justryan's Avatar
Park your Disco in a totally , yes totally dark place , black as a power out .. start the engine , and look at the wires and coil , you will actually see all the leaks ( if any ) then you will know what to change as well .
Old Apr 13, 2015 | 08:56 AM
drowssap's Avatar
glad you found the throttle body heat, I don't think it is your only problem though.
kind of hard for coolant from the exterior to cause a plug to misfire, especially if you have new plugs and wires on there already.
Old Apr 13, 2015 | 09:28 AM
rit1267's Avatar
yup, plug wires arcing against block. such junk, only 3000 miles and they are shot already. can anyone recommend good wires
Old Apr 13, 2015 | 10:10 AM
drowssap's Avatar
kingsborne wire company in cal. get the 8mm wire
http://www.kingsbornewires.com/Searc...001&model=B578
check the fitment
Old Apr 13, 2015 | 03:58 PM
rit1267's Avatar
bypassed the throttle body heater, no leaks, yay!!!!!! I ordered a set of magnacor 8mm, and until they arrive I just bought a cheaper set and changed #1 and #3 wires and she is running like a champ again. thanks all for the help and motivation.
ScreamingLife
Apr 25, 2013 08:32 PM
striversrowatl
May 1, 2010 11:20 AM
Speed racer
Oct 11, 2008 10:56 PM
