Sponsored by: CARiD
02 Range Rover Heater Core Issue!?!?!?!? Thoughts Please!!!
Old May 31, 2007 | 06:50 PM
tgrife's Avatar
5th Gear
Default 02 Range Rover Heater Core Issue!?!?!?!? Thoughts Please!!!
Hey fellas and ladies. I just took my 02 Range Rover in to the dealer to look at a coolant/antifreeze leak that was coming from under the passenger side running board and also a bit coming into the passenger front floor board. I figured that it was the heater core leaking and possibly the O Rings. They diagnosed the issue as the O Rings being fine and just the heater core needing to be replaced. They estimated the cost at $2413.00. I was wondering what you guys feel about this and if this estimate is fair. Any feedback would be greatly appreiciated.
Thanks,
Tim@1010productions.com
Old May 31, 2007 | 07:22 PM
Default RE: 02 Range Rover Heater Core Issue!?!?!?!? Thoughts Please!!!
Maybe fair by dealers standards, it is a bugger of a job, but I would call around to a few shops and get a couple of estimates to make sure.
Mike
Old Jan 24, 2008 | 04:28 PM
bavarian_range89's Avatar
After sitting for about 4 days and coolant leaking into the front passenger foot well does that mean that this is my problem, or can it be another issue? I had a coolant leak before and it was a loose tube, but I just checked the level today and it's low, and after sitting since Sunday I notice some coolant in the front passenger foot well.
Old Jan 25, 2008 | 08:56 AM
raid13's Avatar
so that estimate is JUST for heater core o-rings? no core right?
in the early days you had to remove the whole dash board to do this job
than someone fig. out that you can just cut a hole behind a panel and
due the job in about four hours with about 100 dollars in parts.
if its just o-rings you getting taken.
if it's the core too it seems about right.
russburcham
Jul 26, 2013 06:34 AM
Ted Hill
Aug 20, 2011 06:43 PM
03WhiteDisco
Jul 31, 2009 08:21 PM
tgrife
Jul 1, 2007 02:08 PM
tgrife
Jun 8, 2007 01:32 AM
