Sponsored by: CARiD
03 Disco Expansion tank throttle body nipple cracked %*$#&^@#!
Old Sep 2, 2014 | 09:02 AM
dparham's Avatar
Default 03 Disco Expansion tank throttle body nipple cracked %*$#&^@#!
OK Ive been noticing a low drip occasionally on my cooling system... and seeing coolant around the expansion tank.. suspecting trouble but could not locate source... cap? overpressure? well I found it... the &*%&$ A$$ little nipple under it going to the throttle body warmer was dripping...and coolant would usually stay just under it if I filled it... it would not leak unless cap was on and under pressure.. well now it just leaks so I know thats a problem... I found it because I had plenty of time yesterday replacing defiantly worn water pump... haven't had 4 hrs available for a long time to do this but now I did... anyway... are the affordable aftermarket expansion tanks ok? I see one at miami British down by me that I can get but in the pic it does not show that little nipple! heck Id remove that entire system as its not necessary down here but to keep everything as it is...
I want to get a decent tank... do these come without the TB heater nipple were I could accidentally get the wrong one?
Old Sep 2, 2014 | 09:59 AM
drowssap's Avatar
I replaced mine with an aftermarket which started leaking within months I ended up better off with a used LR part.
Old Sep 2, 2014 | 10:43 AM
acg's Avatar
acg
Land Range Rover Discovery Genuine OEM Factory Coolant Expansion Tank Reservior
Old Sep 2, 2014 | 11:25 AM
drowssap's Avatar
those are aftermarket; says so on the discription
Old Sep 2, 2014 | 11:54 AM
dparham's Avatar
yeah I may go used original if OEM factory new is too pricey for now.... I think the one I have is after market when I bought my disco used.. how do I tell? also do all of them have a nipple that goes to the throttle body heater?
aguison
Nov 16, 2012 09:29 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
DavidG
Jul 11, 2009 09:38 PM
brooksa
Jan 17, 2009 03:09 PM
