Sponsored by: CARiD
'03 Disco STALLING AGAIN!
Old Apr 24, 2017 | 02:21 PM
Jennieedre's Avatar
Angry '03 Disco STALLING AGAIN!
Hello my name is Jennifer. I've used this website to repair my disco for the past year. I just decided to make an account today. So i guess you can say im new lol...
Got my Disco February 2016. Ive had so many different things replaced but recently in january my disco started to stall on me and would take about 20 minutes to start up again.
I changed the Crank sensor and the problem was gone for bout 2 months.
Now the problem is back again! but this time as I'm driving it jerks as if its going to turn off, but never turns off.
UNTIL TODAY! It turned off on me while at a red light and it took about 10 times cranking it for it to finally start up again.
Old Apr 25, 2017 | 04:03 AM
The Deputy's Avatar
Are you getting a check engine light on the dash? Might be a good time to have codes checked, regardless...in case check engine light has been disabled. Any OBD tester will read codes, or parts store.
If no codes, may want to have the fuel pressure tested. There is a port on the backside of the fuel rail, under upper manifold, drivers side. Also, may want to revisit the crank sensor...if fuel pressure checks out okay.
Brian.
Old Apr 27, 2017 | 01:04 AM
abran's Avatar
^ good advice. Also post up where you are, maybe a local member will help!
abran
Jun 30, 2014 12:43 PM
Rover5150
Dec 10, 2007 07:55 PM
pman
Sep 19, 2006 04:04 PM
slamwhit
Jun 17, 2005 05:11 PM
trailhead4x4
May 25, 2005 08:48 PM
