Sponsored by: CARiD
04 Disco coolant leak
Old Oct 1, 2017 | 03:35 AM
Tyson Kuhlenbeck's Avatar
4th Gear
Default 04 Disco coolant leak
Hey guys attached a few pics. Where is my leak? Safe to drive when I watch the levels?
Old Oct 1, 2017 | 07:28 AM
Looks to be in the area of your coolant expansion tank. Could be the tank, could be a hose, could be a loose csp or a blown head gasket.
I would figure out the problem instead of driving and topping off. I'm weird though I hate pulling motors to replace them.
Old Oct 1, 2017 | 09:10 AM
OverRover's Avatar
AR is right, retake this pic over the top and sides of the coolant expansion tank. Even in that pic you can see the leak (white res) came from the tank, cap, etc as AR mentioned.
Should you drive it until it's fixed...NO! And when you do get it fixed please get the Dexcool out of this poor thing. Good Luck!
Old Oct 1, 2017 | 11:08 AM
Best4x4's Avatar
I say it's a cracked nipple at the bottom of the tank or the tank itself. New one on Ebay is around 40-50.00.
Old Oct 1, 2017 | 05:31 PM
4th Gear
Old Oct 1, 2017 | 06:06 PM
4th Gear
Thank you!
Old Oct 1, 2017 | 06:07 PM
4th Gear
Old Oct 1, 2017 | 08:08 PM
Best4x4's Avatar
Looks like it's either leaking between the jug & the neck, or from the hose connected to the neck or from the aftermarket cap itself. I'd replace the jug, and while your at it convert over to the green coolant vs that red stuff that does not do so well in LR V8's.
ZMonet
Jun 24, 2016 04:00 PM
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
nolabrooke
May 21, 2010 09:33 AM
lipadj46
Jul 8, 2009 07:41 PM
