Sponsored by: CARiD
'04 Discovery Key Programming
Old Jun 13, 2014 | 06:55 PM
OCMike's Avatar
Default '04 Discovery Key Programming
I've tried searching, but I don't think I'm using the right search terms. I just picked up an '04 discovery and cannot get the key fob to remotely unlock the doors. Is there a way to resync them to the truck, or do I need to go to the dealership? I've changed the batteries in both, and the both have the same 6 digit code.
Old Jun 13, 2014 | 10:10 PM
tuercas viejas's Avatar
Mike
You don't have to go to a dealer but a good LR Independent shop with an Autologic can do it.
Firstly some "self help" might be useful:-
Verify the fobs you have are transmitting an RF signal!
To do that go to an Advanced Auto parts store and beside the key fob battery display should be a tester. Switch it on and fire the key at the tester, if the light blinks its good to aim at your car.
Now the next thing is to remember that the car has an RF receiver and the antenna is inside cant rail area near the rearmost side glass--the two lines are antennas by the way.
Aim the fobs and see if you have any activity.
Now in the hands of someone with an Autologic or dealer scanner delving into the security system will show if the system is seeing a signal or not and it will confirm if the fob circuit boards you have inside the key are programmed to the system; the small labels with the code on the board will confirm that.
It might be that the security code memory is maxed out by the use of by by now lost keys and it won't accept any new key codes until some of that old stuff is cleared out.
Expect to pay about $75 for a program exercise the dealer is around $125 to $200.
Hope that helps you
T/V
Old Jun 14, 2014 | 01:39 AM
OCMike's Avatar
I did notice that if I locked the door, then held down one of the buttons, the alarm light would start blinking faster.
Old Jun 14, 2014 | 11:44 AM
LR Techniker's Avatar
Maybe a silly question but didn't see mention of it: do the locks work via the Central Locking button?
Old Jun 14, 2014 | 03:55 PM
OCMike's Avatar
Yes, they do. Also, the doors are not automatically locking when I put it in drive and go over 10 mph. Just noticed that yesterday. Probably not related, but a new thing I need to figure out.
Old Jun 14, 2014 | 03:57 PM
OCMike's Avatar
And, thanks T/V. I'll call some shops next week to see if any of them reprogram keys.
Old Jun 15, 2014 | 12:56 PM
No its not a silly question--because that would be my next question as well!
Basically that would be the next check!
Does the central lock system work?
T/V
Old Jun 16, 2014 | 12:30 AM
OCMike's Avatar
T/V
Center locking button does work. If you are talking about the lock/unlock button on the dash.
Old Jun 16, 2014 | 02:15 PM
OCMike's Avatar
So, I took the Rover to an independent shop to see if they could get the keys to work. They hooked up an Autel and got to the key programming screen, but it would not accept the keys. The technician thinks there might be something wrong with the ECM, since the screen on the autel was flickering and not displaying text on some of the buttons.
So, now I don't know what to do next. Do I take it to another shop that specializes in Land Rovers, or do I head to the dealer?
Old Jun 17, 2014 | 12:57 PM
OCMike's Avatar
Apparently, the culprit is a bad RF receiver module? Indy shop quoted me about $350 to replace and program. Anyone know if that's a good price?
bballjames
Apr 9, 2013 10:51 AM
llaverosv
Freelander
Aug 5, 2008 12:13 AM
meltdowndave
Apr 26, 2008 03:54 PM
HollandandHolland120
Oct 18, 2007 06:49 PM
Ahhsk
Mar 12, 2007 03:27 AM
