Sponsored by: CARiD
04 Range Odometer Not showing up
Old May 25, 2008 | 12:30 AM
Young's Avatar
Default 04 Range Odometer Not showing up
Its just not there... Is there a fuse that governs this or can it be turned on or off..... The mileage is just not showing up???? Please help..... And I mean the digital display...... Its not showing up.....
Old May 25, 2008 | 08:12 AM
Default RE: 04 Range Odometer Not showing up
Get it to the dealer and see if they can scan and reset your odometer. If they can, great, if not you are looking at buying another one.
Old May 25, 2008 | 10:08 AM
Young's Avatar
Ok so there is no fuse or plug that I can check to see if its loose or shortageout......
Old May 25, 2008 | 12:03 PM
WolfPack's Avatar
Mike do the 04s have simple incandescent bulbs doing the backlighting on the display like the P38s do? He might just have a blown bulb if the are.
Old May 25, 2008 | 01:40 PM
Young's Avatar
ORIGINAL: WolfPack
Sorry I meant to type 03
Old May 27, 2008 | 06:55 PM
roverguy7's Avatar
is there nothing at all, no light, or is it green and no numbers??
Old May 28, 2008 | 11:54 AM
Young's Avatar
Green Lights and No Numbers
Old May 28, 2008 | 08:50 PM
roverguy7's Avatar
i want you to try this and see what happens, if it shows anything in that box... with the doors shut, press and hold the rh button on your instrument pack, the one under the tach, with it held turn the key to position 1, aux. itll say "testnr:01"... let off the button once it does, now press the button again, just once, not holding it down, and itll say "testnr:02" when it does hit the other button, your trip reset button on the left side of the i/p. itll go through a test sequence, after everything stops moving, maybe up to 30 seconds, turn the key off for 2 minutes. watch where your miles should be during this test, see if it goes black, if not, its your lcd display in your instrument pack, and youll need a whole new one, if it does go black, then itll either start working fine after you cycle the key, or ill need you to do something else, but ill have to talk you through that one on the phone. let me know what happens
Old Jun 6, 2008 | 06:28 PM
Young's Avatar
Ok let me try that...... ive been out of town on business.......lemme check it out
Old Aug 29, 2011 | 07:16 AM
sysroute's Avatar
Hey guys. Any idea on what is involved if the green light on the right side of the dash is no illuminating? There are two green lights that are behind the information panel and the right one stopped working...
cozbet
Feb 25, 2014 08:42 AM
cozbet
Feb 24, 2014 12:38 PM
philander
Aug 19, 2011 04:20 PM
sfxgamer
Nov 28, 2007 07:18 PM
sfxgamer
Aug 17, 2007 09:05 AM
