Sponsored by: CARiD
05 LR3 V6 check engine light
Old Oct 21, 2011 | 09:44 AM
rvrguy's Avatar
Default 05 LR3 V6 check engine light
Check engine light popped up the other day. I pulled out fault codes p0108 Map/Baro circuit fault, p0069 Map/Baro correlation, and p0741 torque convertetr performance. Anyone have these faults?
Old Oct 21, 2011 | 07:04 PM
Have the battery and alternator tested, I dont know about the LR3 but on the DII when it throws those type of codes it usually means low battery voltage.
Old Oct 22, 2011 | 09:25 PM
Rovin4life's Avatar
check ford forums, the V6 is a ford mustang motor.
Old Aug 4, 2014 | 12:06 AM
bobbydigital69's Avatar
I also have a 2006 v6 lr3 w same issues and codes. What was the end result in fixing this issue?
Thanks,
Robert
Old Aug 15, 2014 | 01:53 AM
Tony Back's Avatar
mine has the same issue once. my mechanic examed it with a Mangoose scanner and cleared fault code. He recommended me to get one because it designed for JLR.
ghtaylor
Feb 15, 2016 06:01 AM
FlyingZebra34
Feb 22, 2014 05:39 PM
Jeremiahbullrog
Apr 21, 2012 06:17 AM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
