Sponsored by: CARiD
05 LR3 Won't Shift into D When Hot
Old Aug 3, 2010 | 10:03 PM
challishodge's Avatar
4th Gear
Default 05 LR3 Won't Shift into D When Hot
2005 LR3 (80K miles) won't shift into Drive after its been driven for a while in hot weather (typically 85F+ ambient temperature or hotter). Park and Reverse are fine. Won't shift into sport either. If I do get it into gear it will drop in and out of Drive at speed. Dash D indicator goes on and off accordingly. Once it cools it's fine.
Old Aug 4, 2010 | 11:32 AM
4th Gear
Hi Everyone,
Please let me know if I'm positing in the wrong place or not likely to get a response. I need to figure out next move fairly soon. Thanks!!
Old Aug 5, 2010 | 12:17 AM
Rovin4life's Avatar
bushing is rusted up on the transmission its where the cable meets the selector shaft. you can take it off and clean it up but be careful you don't snap the cable.
Old Aug 5, 2010 | 07:25 AM
4th Gear
Thanks I'll check it out.
Is it tough to get to on this vehicle?
Old Aug 5, 2010 | 10:49 AM
4th Gear
Whats the best way to access? Console removal? Any pointers on 05 LR3 console removal?
Old Aug 7, 2010 | 11:06 AM
Rovin4life's Avatar
underneath the vehicle. there is a plate with four screws over the transmission. you will see the cable.
sjewell
Sep 12, 2019 11:55 AM
importdave
Sep 25, 2014 10:18 PM
Ringo
Jul 26, 2011 11:59 AM
KBW
May 23, 2010 03:35 PM
discotx
Dec 22, 2007 10:08 AM
