Sponsored by: CARiD
05 range rover hse loud engine noise
Old May 14, 2017 | 03:55 AM
Ada2016's Avatar
4wd High
Default 05 range rover hse loud engine noise
Hi everyone.
I changed my 05 range rover hse water pump thermostat assy and all the hoses on Thursday ever since my engine sound like a diesel engine. I have been searching in other forum to find the issue with no luck. SomeOne Mentioned The Secondary Air Injection Cross Link Pipe Not Setting Straight In The Hole. And why I don't understand is my range has a SAI cross link pipe with the valve in the center but there is no hose connected to either of the side of the valve. I removed the valve prior to removing the pipe wondering if the valve holes were sealed but not sure the sound seems to be a leak. Has anyone experienced this b4 or can someone explain the SAI in the range rover
Thanks in advance
eandrews2
May 11, 2013 03:57 PM
Adsan1280
Jan 2, 2013 02:52 PM
ColeMayfield
May 5, 2011 01:44 PM
Rayred
Sep 20, 2010 02:27 PM
tcbinaflash
Jan 8, 2008 04:23 PM
