Sponsored by: CARiD
06 LR3 Electrical Issues
Old Feb 1, 2014 | 08:51 PM
mikest75's Avatar
Default 06 LR3 Electrical Issues
I hope someone can give me some tech advise. I have a 06 LR3 that is giving me an engine system fault, transmission fault, and an HDC fault message. Please help! I think it is something in the electrical system. Thanks for any help anyone can give.
Thanks,
Michael
Old Feb 2, 2014 | 02:57 PM
tuercas viejas's Avatar
Michael
Its is very hard to diagnose such issues without using a factory style scanner.
Often communication issues are the base problem including Can Bus issues.
If you don't want to use a dealer in your area for a scan try to locate an Independent shop with say an Autologic scan tool. You can often find a shop with the tool in your area by phoning Atlantic British (they used to sell it) or calling Autologic direct in NY.
Amistades
T/V
Old Feb 5, 2014 | 07:55 PM
Rover2013's Avatar
sounds like a bad battery and the acid leaked into the transfer box ECU. But this is just a guess.
Old Feb 6, 2014 | 06:35 PM
LR Techniker's Avatar
There is a ton of things it could be. Battery issues and brake switch failures are the two I would suspect first, but these are just GUESSES and the vehicle really needs diagnosed.
nh9095
Jan 14, 2019 12:36 AM
jobob307
Jul 2, 2008 07:26 PM
95raingerowver
Feb 19, 2008 07:28 AM
dustin309685
Nov 18, 2006 07:45 PM
russ00001
Aug 6, 2006 03:54 PM
