Sponsored by: CARiD
0734 Fault Code
Old Jan 1, 2013 | 06:27 PM
riko suave's Avatar
The other codes were 7600 and 0007 but I didn't have the description of those in my scanner booklet.
Old Jan 1, 2013 | 07:50 PM
LR Techniker's Avatar
Do you have all your gears? Any flare going into gear?
Does your scanner read codes only, or does it show OBDII data as well?
Old Jan 1, 2013 | 08:21 PM
riko suave's Avatar
Yeah all the gears seem to be ther.
My OBD only reads the codes and gives me the short description, no data.
I'll try cleaning the MAF with the CRC cleaner and see if that helps.
Old Jan 2, 2013 | 04:58 PM
Definitely go that route first, I just wish you could reset the fuel trims when you are done for maximum effectiveness.
skunkridge
Sep 17, 2024 05:47 PM
06Range
May 8, 2013 09:01 PM
sayeedA
Nov 15, 2011 11:02 PM
Charles68
Apr 2, 2008 01:37 PM
