12V source for switch power?
Hi all. I'm trying to rig up a toggle switch to run my Hella 4000's off the relay and need a source for power for the two-position switch. I'd rather not run 10 plus feet of wire to tap into the headlight harness. Is there an easier place within the cabin to get power without using a fuse tap? Wire-tap it from the fog switch? What color is the hot wire for the cigarette lighter?
I plan on installing the switch on the front of the center console storage box so I can just toggle on/off without having to reach up and hit the stock switches on the dash.
Thanks!
Thanks!
Hi Savannah. I want to modify the cigarette lighter wiring on my son's 2003 Discovery II so that he may charge his phone without the key having to be in the ignition.
I saw your response in this thread (URl pasted below) where you mentioned the "light green with white for the lighter". What did you mean by this? Is there a green/white wire somewhere that I can tap into so the cigarette lighter will always have 12v power (without the key)?
Source Post >> https://landroverforums.com/forum/ge...h-power-56915/
In the previous case he wanted the existing switched 12 volt wire to the lighter. You want hot all the time. Install a new lighter plug, with a fuse between it and the brown with white wire on the back of the fuse panel, connector C0583 - pin 3.
Be careful with added wiring, it always needs a fuse.
thearmlesswonder
05-02-2013 10:00 PM
Phototone
04-16-2008 01:14 AM
