Sponsored by: CARiD
12V source for switch power?
Old Feb 19, 2013 | 08:19 PM
keoni004's Avatar
Default 12V source for switch power?
Hi all. I'm trying to rig up a toggle switch to run my Hella 4000's off the relay and need a source for power for the two-position switch. I'd rather not run 10 plus feet of wire to tap into the headlight harness. Is there an easier place within the cabin to get power without using a fuse tap? Wire-tap it from the fog switch? What color is the hot wire for the cigarette lighter?
I plan on installing the switch on the front of the center console storage box so I can just toggle on/off without having to reach up and hit the stock switches on the dash.
Thanks!
Old Feb 20, 2013 | 01:29 AM
light green with white for the lighter.
Old Feb 20, 2013 | 04:16 PM
keoni004's Avatar
Thanks Savannah!
Old May 29, 2013 | 07:02 PM
buztan99's Avatar
5th Gear
Hi Savannah. I want to modify the cigarette lighter wiring on my son's 2003 Discovery II so that he may charge his phone without the key having to be in the ignition.
I saw your response in this thread (URl pasted below) where you mentioned the "light green with white for the lighter". What did you mean by this? Is there a green/white wire somewhere that I can tap into so the cigarette lighter will always have 12v power (without the key)?
Source Post >> https://landroverforums.com/forum/ge...h-power-56915/
Old May 29, 2013 | 08:41 PM
In the previous case he wanted the existing switched 12 volt wire to the lighter. You want hot all the time. Install a new lighter plug, with a fuse between it and the brown with white wire on the back of the fuse panel, connector C0583 - pin 3.
Be careful with added wiring, it always needs a fuse.
Perfectphoto
May 31, 2015 04:39 PM
thearmlesswonder
May 2, 2013 10:00 PM
Antmen
Sep 13, 2012 01:01 PM
newBrover
Jul 25, 2010 04:57 PM
Phototone
Apr 16, 2008 01:14 AM
