Sponsored by: CARiD
1996 LR Discovery
Old Jun 24, 2016 | 01:48 PM
DonnaLandRover's Avatar
4wd High
Default 1996 LR Discovery
HELP.... during the hot summer days, it refuses to crank. Cranks in early morning before outside temp gets high (mid 80's-upper 90's ) then will crank in the evening once outside temps drop. Have been stranded one too many times. The first time it happened, was last summer, i waited for an hour for a tow truck to pick it & ME up to be taken to a mechanic & as soon as it was off the tow truck & the mechanic ask me to try cranking it so he could see what it was doing, IT CRANKED RIGHT UP...WHAT A WASTE OF A TOW BILL THAT DAY! IT IS A DAILY PROBLEM THIS SUMMER!!! ANY SUGGESTIONS???
Thanks,
Donna
Old Jun 24, 2016 | 05:43 PM
Shiftonthefly1's Avatar
Crank position sensor.
Old Jul 7, 2016 | 05:15 PM
4wd High
Thank you I will give that a try
Old Jul 8, 2016 | 01:34 AM
number9's Avatar
Referring to starter not turning over engine? If so may be the starter going tango uniform. Crank position sensor shouldn't prevent starter from turning over engine.
Old Jul 23, 2016 | 07:37 AM
4wd High
It turns over & only does it during summer months. What if any difference is there between Crank Sensor & Crankshaft Position Sensor?
Old Jul 23, 2016 | 08:57 AM
number9's Avatar
No difference. Have read previously eng light may be on while cranking if sensor is failed or in your situation when hot and won't start.
Crankshaft position sensor (CKP Sensor)
The crankshaft position sensor is the most important
sensor on the engine. It is located in the left hand side
of the flywheel housing and uses a different thickness
of spacer for manual and automatic gearboxes. The
signal it produces informs the ECM:
- the engine is turning
- how fast the engine is turning
- which stage the engine is at in the cycle.
As there is no default strategy, failure of the
crankshaft sensor will result in the engine failing to
start. The fault is indicated by illumination of the
malfunction indicator light (MIL) on North American
specification vehicles.
pzwerner
Mar 25, 2007 10:01 PM
newb
Appearance & Camping Set Ups
Mar 11, 2006 06:01 AM
tjsteph
Feb 9, 2006 10:43 PM
bboat567
Jan 15, 2006 11:15 PM
mauemiliani
Dec 6, 2005 05:04 PM
