Sponsored by: CARiD
1997 disco engine help please
Old Dec 25, 2005 | 02:25 PM
razorbak's Avatar
Default 1997 disco engine help please
1997 Disco I automatic tranny. About three weeks ago, I pulled up to a stop light, (at operating temerature and running for a few miles) and the engine dropped down to about 400 rpm for a couple of seconds like the engine was going to die, then jumped back up to normal. Since then, it seems to do this once every time I drive it, not every time though.....Yesterday, it was hard to start for the first time, and after starting, it barely ran for a few seconds, then suddenly the rpms came up to normal and it ran like normal. What is going on?
Thanks for any help!
Old Dec 25, 2005 | 02:28 PM
razorbak's Avatar
Default RE: 1997 disco engine help please
Sorry, forgot to mention it has 106k miles.
Old Dec 25, 2005 | 08:44 PM
05LandRover's Avatar
try checking the connections to all of your sensors, example: iac, 02, tps, maf, map, etc
Old Dec 26, 2005 | 12:00 PM
JRdisco1's Avatar
also may want to check the vss sensor possibly. is it throwing any codes/lights etc.?
Old Dec 26, 2005 | 04:17 PM
razorbak's Avatar
Everything seems to be connected. The only code that is popping up is for the ABS system....I've had the system disconnected since I've owned the vehicle, as it was malfunctioning, so I pulled the fuse and just don't have ABS. No new codes though.
What about the fuel system? Do rovers have any common problems that pop up?
Old Dec 27, 2005 | 01:20 AM
mikemeyer0's Avatar
2 things:
Your MAF needs cleaning. (do you have a K&N air filter?)
Sounds like the idle air valve (or "stepper motor"), located on the front of the intake plenum about midway. Remove and clean often fixes it.
Old Dec 27, 2005 | 10:34 AM
Landzu's Avatar
It could be the fuel temperature sensor if this is going out it will
not let the ECM know how much fuel to use.
Some of the affects are bad idle, hard starting.
Its on the fuel rail.
I don't know how to see if its still good.
lol Mike
Old Dec 27, 2005 | 05:43 PM
Hank's Avatar
Sounds like stepper motor. Unless your speed-o is doing weird things too. Then, it might be a VSS...I still bet stepper motor, like Mike said.
Old Dec 28, 2005 | 10:26 AM
Landzu's Avatar
I checked my workshop manual last night and if any sensor on the fuel sys
was going out it would set the MIL light.
Is the truck doing anything else?
Old Dec 30, 2005 | 04:19 AM
skipdow's Avatar
3rd Gear
that exact thing just happened to one of my discos...changed the throttle position sensor and it was fixed
Wasseem
May 8, 2013 11:46 AM
c670809
Dec 11, 2012 10:48 AM
jgarcia
Oct 18, 2008 07:12 PM
chrisandsarah
Nov 30, 2007 03:35 AM
