1997 Land Rover 4.0 SE Radio problems
Old 05-14-2014, 01:32 PM
Paul Grant's Avatar
Sam, you can call your Range Rover whatever you like as long as you're prepared to sift through the different answers you're going to get. People usually call your Range Rover model a P38 as that was the production code number given to it during its development. That separates it from the Range Rover Classic which preceded your truck and the L322 that came after.
Now, going back to your issue. I think you're definitely on the right track. I'm not sure what the link you posted is for but it appears to be broken, at least when I tried it. You should go here:
land rover service factory manual RAVE download land rover resource, service manual, workshop factory manual, download, rave, vehicles including discovery, series, defender, range rover, freelander, LR3, Handbooks, Catalog, Catalogue, Land Rover Inte
Download all the manuals. You will find an ETM for your specific truck with an entire section, E6 devoted to trouble shooting the radio. At least you'll have schematics to follow.
Good luck,
Paul
Old 05-15-2014, 06:13 AM
1999SE40's Avatar
According to the book I have it's behind the panel that covers the rear Pass/side cargo cover wall. I will have to look at my other post someone gave me a link to all the shop manuals.
Old 05-15-2014, 06:27 AM
1999SE40's Avatar
The clutch coil is a unit and when you pull the pulley it is one piece you will be left wits the compressor and a stubby shaft that is usually keyed. See if you have a Robin Air dealer or Red Line parts vendor in your area they will have an aftermarket clutch for you. When you install it push it over the key by hand and then install the belt and energize it (turn on AC so clutch locks) and torque it Not sure what the torque is but it should be the same as a Ford or Chevy with the same type compressor.
michelleconlon
04-08-2015 09:15 AM
cheqbay1997
10-24-2012 09:02 PM
Panic
04-27-2009 08:54 AM
Blackus2009
02-24-2009 05:44 AM
discoverystar
07-24-2006 10:14 PM
Quick Reply: 1997 Land Rover 4.0 SE Radio problems
