Sponsored by: CARiD
1998 Range Rover HSE Misfire Problem
Old Feb 13, 2010 | 01:32 PM
DannyBoy's Avatar
Default 1998 Range Rover HSE Misfire Problem
Hi everyone!
I have a 1998 Range Rover HSE that has a misfire problem, throwing codes P0300 and P1316.
So far I have done the following:
Replaced plugs and wires
Replaced fuel filter
Run injector cleaner
Checked fuel pressure
When I checked the fuel pressure, I got a reading of 30 PSI. The spec for delivery pressure is 34-37 PSI, so I dont know if my fuel pressure is low enough to constitute a misfire.
The fuel injector cleaner seemed to help a little, but after clearing the codes they came back on within a few miles.
My next move is going to be testing the Coils and perhaps lowering the fuel tank and making sure there is no water/debris in it. And having a look at the fuel pump.
If anyone has had a similar problem, or has any advice i would greatly appreciate your thoughts!
Thanks,
Old Mar 12, 2011 | 05:05 PM
thegreenrangie's Avatar
Default same problem on 1996 4.6 hse
Hey Danny Boy,
what did the cause of your problem turn out to be? I have same problem, 0300 0316 codes, idles fine, but won't rev over 1500 rpm, and i have 30psi fuel pressure.
please help asap!!!
Tom
cduncan
Jul 26, 2010 08:46 AM
rasco
Sep 17, 2009 06:07 AM
37chambers
Jul 8, 2007 05:43 PM
03disco
May 26, 2007 10:33 PM
roverover
Aug 15, 2005 01:17 AM
