1999 Disco Series I Wheel Hub Assembly
So I found this one on a site for $73...it says it fits the Series I...then this other site says it doesn't fit the series I....RockAuto doesn't even have a assembly for the series I...please tell me that I will be able to use the $73 one and not have to find some $250+ assembly
Yeah it's the wheel bearings...my front passenger side is bleeding through the hug (oil/grease) and was told if I was doing One I might as well do both...but I heard replacing the hub is easier than replacing the bearings in it? I did find 2 used hubs in great condition for $108...should I stick with that or ?
At worst new bearings should only be $30 or so.
Are you confusing D1 hubs for the sealed D2 hub units ?, there is no need to replace hubs on a D1. Unless the seal has been stuffed for a while and bearings run dry all they will need is to be repacked with grease and a new seal fitted.
