Sponsored by: CARiD
2000 DII ignition left on 3 hrs
Old Aug 27, 2012 | 01:58 PM
Sea Paddler's Avatar
Default 2000 DII ignition left on 3 hrs
Tale from mother in law. Left ignition on for three hours and tanked the battery, got it jump started and came home. Now I've taken it for a drive and found that at idle and low or soft throttle application it is haltingly rough. At heavier throttle application the roughness is not apparent. Any thoughts?
Thanks!
Old Aug 27, 2012 | 02:32 PM
Maybe the ECU reset (or lost) some stored adaptive values, and it is in the process of re-learning the engine and specific wear patterns on the throttle parts, etc. I'd drive it for several drive cycles and see if it improves, if it does you may have hit on a way to reset adaptive values without a trip to the dealer.
will rocket
Off Topic
Sep 12, 2013 06:23 AM
94svt50
Aug 27, 2013 03:17 PM
SkymonkeyONE
May 8, 2013 10:40 AM
1998DiscoverySE
Jun 27, 2012 01:56 PM
Different Drummer
Jan 18, 2011 08:11 AM
