2001 Discovery II Problems
Do some digging around on the Interweb about the D2 cooling system. Tons of info out there. One of the main points is the factory temp gauge is complete crap.
It doesn't crank? Or doesn't run? Do the hoses feel hard? I'm assuming you've checked coolant level. Any bubble sounds? Have you maintained this truck or is this a new purchase? Gonna need more information to try and even pinpoint a problem.
If not over heating you may have a failed ECT sensor or wiring to it.
Manual:
Manual:
In the event of an ECT sensor signal failure any of the following symptoms may be observed:
l Difficult cold start.
l Difficult hot start.
l Driveability concern.
l MIL illuminated.
l Instrument cluster temperature warning lamp illuminated.
l Temperature gauge reads excessively hot.
l Temperature gauge reads excessively cold.
l Cooling fan will not run.
l MIL illuminated.
