Sponsored by: CARiD
2001 Discovery II Problems
Old Apr 19, 2016 | 05:54 PM
Jovan.m.padia@comcast.net's Avatar
4wd High
Default 2001 Discovery II Problems
My Disco 2 high temperature light just came on but the needle is pinned to the bottom, pulled over checked for over heating and found nothing. When to start it back up and now it won't start?
Old Apr 19, 2016 | 05:59 PM
Shiftonthefly1's Avatar
Do some digging around on the Interweb about the D2 cooling system. Tons of info out there. One of the main points is the factory temp gauge is complete crap.
It doesn't crank? Or doesn't run? Do the hoses feel hard? I'm assuming you've checked coolant level. Any bubble sounds? Have you maintained this truck or is this a new purchase? Gonna need more information to try and even pinpoint a problem.
Old Apr 19, 2016 | 09:33 PM
number9's Avatar
If not over heating you may have a failed ECT sensor or wiring to it.
Manual:
In the event of an ECT sensor signal failure any of the following symptoms may be observed:
l Difficult cold start.
l Difficult hot start.
l Driveability concern.
l MIL illuminated.
l Instrument cluster temperature warning lamp illuminated.
l Temperature gauge reads excessively hot.
l Temperature gauge reads excessively cold.
l Cooling fan will not run.
Unshriven
Apr 7, 2010 07:02 PM
Unshriven
Feb 28, 2010 01:29 PM
johnkbl
Jan 19, 2010 05:22 AM
damnlows10
Jun 23, 2008 06:35 PM
nrbbnb
Jan 21, 2008 04:45 PM
