2001 discovery starting problem
RE: 2001 discovery starting problem
This may not be your problem however, I had the exact problem with a Camero back in the day, I was told I had a pin hole in my radiator hose and it was causing the engine to vapor lock, after the engine cooled down it would fire right up fine until it got hot again then it would shut down. Changed both hoses - refilled fluid, never happened again.
Robert
Robert
cobralootman
12-05-2006 02:38 AM
