Sponsored by: CARiD
2001 discovery starting problem
Old Dec 8, 2008 | 09:41 PM
mindo121's Avatar
Default 2001 discovery starting problem
Hi,i cant restart ,when engine is hot,after 10 minutes start right up.Cold starts no problem,please help,thanks Mindo
Old Dec 8, 2008 | 10:35 PM
Willie 00D2's Avatar
Default RE: 2001 discovery starting problem
Is your service engine light on?
Willie
Old Dec 8, 2008 | 10:55 PM
Night Train's Avatar
This may not be your problem however, I had the exact problem with a Camero back in the day, I was told I had a pin hole in my radiator hose and it was causing the engine to vapor lock, after the engine cooled down it would fire right up fine until it got hot again then it would shut down. Changed both hoses - refilled fluid, never happened again.
Robert
Old Dec 9, 2008 | 08:48 AM
Mindo, you may have a crank sensor failing. Just to make sure I read you right, the engine will crank but not start up? This will cause what you are describing and yet not throw a code.
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
djaaronreed
Dec 7, 2013 11:01 AM
Unshriven
Feb 28, 2010 01:29 PM
akin613
Sep 20, 2008 09:33 AM
cobralootman
Dec 5, 2006 02:38 AM
