Sponsored by: CARiD
2002 Disco 2 engine sound- HELP!
Old Jun 10, 2015 | 09:20 PM
cezeta62's Avatar
Default 2002 Disco 2 engine sound- HELP!
Hello all, I need some help with diagnosing an issue with my engine.
It's a slight knocking
Go to:
https://youtu.be/tK_bZO6F99E
Check out that YouTube video of the engine running and give me some feedback
Thanks,
C62
Old Jun 11, 2015 | 01:08 PM
justryan's Avatar
with the cheap acoustics i have here ... it sounds like a bearing knock, or piston slap , does it get louder when you rev the engine ?
what we would do is take off all the external belts on an engine , and then start the engine without the fan blowing the sound all over the place , you will be better able to hear where its coming from , ohh and you could get a piece of hose 3 ft or so ,and make a home made stethoscope to listen at the top and block area for the knock ... then we will then analyse the results ....
Old Jun 11, 2015 | 01:47 PM
cezeta62's Avatar
Yeah, it gets louder and more defined when the engine is reed or when I'm driving it. I'll try taking the belts off in order to get a clearer sound.
So, do both of these issues (bearing knock, or piston slap) - do they require yanking the engine out?
Old Jun 11, 2015 | 03:32 PM
justryan's Avatar
if its getting a lot louder ,its more leading to bearing knock , and yes you best pull the engine out and do a complete job on it ,,,,,, ,or replace the complete head and block ... ( will save some money )
but we heed to get to to exact problem first ... let me know what you hear and where ...
Old Jun 11, 2015 | 06:53 PM
loanrangie's Avatar
Could also be the dreaded loose liner which is engine out and rebuild time.
Jeremiahbullrog
Apr 21, 2012 06:17 AM
heinzeman
Nov 19, 2010 07:53 PM
mvjimenez
Jun 12, 2010 10:25 AM
Wilbert
Audio/Visual Electronics
May 12, 2009 07:25 AM
tfenske
Jul 12, 2006 04:58 PM
