Sponsored by: CARiD
2002 lr disco2 wont start
Old Jan 21, 2009 | 01:16 PM
lrlover's Avatar
4wd High
Default 2002 lr disco2 wont start
I have a 2002 land rover discovery 2 it will not start. I went out in the morning to start it and it cranked just fine, shut it off about 5 minutes later and now it wil not crank at all, nothing at all. I can hear the ignition module cclicking under the hood but it does nothing. I had the battery checked it is in perfect shape. It was a little cold out this morning around 32 deg. but like i said it cranked just fine. Please help i am at a lose.
Old Jan 21, 2009 | 01:45 PM
Default RE: 2002 lr disco2 wont start
What you are hearing is your starter's solenoid clicking, not your ignition.
Who checked your battery and how, what was the voltage and alternator charge rate?
Old Jan 22, 2009 | 09:15 AM
lrlover's Avatar
4wd High
advance checked it and the voltage was12.86v cca were 753 and it was measured at a temp of 57 f. Also i do not hear the solenoid at all the little clicking i heard came from the fuse box under the hood from one of the relays.
Old Jan 22, 2009 | 01:33 PM
Minimum voltage on a Rover is 13.6 volts, maximum is 14.4
Get the battery charged, take the truck and have a oad test done to verify what the alternator is putting out.
Old Jan 24, 2009 | 05:10 PM
lrlover's Avatar
4wd High
Thanks Disco Mike for the advice, it ended up being the starter, the brushes were shot.
Old Jan 24, 2009 | 05:12 PM
lrlover's Avatar
4wd High
Thanks Disco Mike for the advice, but it ened up being the starter the brushes were shot.
disconic
Jun 4, 2016 02:57 AM
gustav23
Dec 15, 2011 01:12 PM
ntavila
Jan 1, 2011 04:17 PM
slave600
Feb 28, 2009 02:33 AM
millejdq
Jan 11, 2007 12:00 PM
