2003 D2 overheating
2003 D2 overheating
Hi all,
I have a 2003 d2 SE with about 160k miles. It just won't stop overheating.
I replaced the water pump as the bearing failed. It ran fine for a week or so but started overheating again. I drained and flushed the system and it didn't work. I then replaced the thermostat with a 180° but still nothing. I've replaced the radiator next and still overheating. I then replaced the thermostat again but nothing. Finally, I replaced the fan clutch and fan and again, still overheating. Heater and ac work fine.
I'm using zerex g05 for coolant and diluting to about 70%water.
I just ordered a new aux fan to see if that is it but I'm at a loss. I'm not losing coolant, there is no air in the system, and oil looks clean.
Any thoughts?
Any thoughts?
Thank you. I was hoping that it wouldn't be that because it was a pain to replace but I'll give that a shot. I'll also take your advise on posting in the D2 section. Thanks again!
