Sponsored by: CARiD
2003 D2 overheating
Old Mar 11, 2023 | 04:38 PM
D2needs's Avatar
Default 2003 D2 overheating
Hi all,
I have a 2003 d2 SE with about 160k miles. It just won't stop overheating.
​​​​​I replaced the water pump as the bearing failed. It ran fine for a week or so but started overheating again. I drained and flushed the system and it didn't work. I then replaced the thermostat with a 180° but still nothing. I've replaced the radiator next and still overheating. I then replaced the thermostat again but nothing. Finally, I replaced the fan clutch and fan and again, still overheating. Heater and ac work fine.
I'm using zerex g05 for coolant and diluting to about 70%water.
I just ordered a new aux fan to see if that is it but I'm at a loss. I'm not losing coolant, there is no air in the system, and oil looks clean.
Any thoughts?
Old Mar 11, 2023 | 10:02 PM
Harvlr's Avatar
Hi D2. Welcome to the forum. You should post your technical questions in the Disco 2 section of this forum, you’ll get way more traffic. I’m not the expert, but my first guess would be the part that you just replaced, a bad water pump.
Old Mar 11, 2023 | 10:29 PM
D2needs's Avatar
Thank you. I was hoping that it wouldn't be that because it was a pain to replace but I'll give that a shot. I'll also take your advise on posting in the D2 section. Thanks again!
Liamcbishop
Feb 23, 2023 08:42 AM
dmenchaca1966
Oct 7, 2022 04:10 PM
austinlandroverbill
Aug 19, 2019 06:26 AM
Salone Roamer
Jul 8, 2012 10:25 PM
cowgirl1989
Aug 30, 2005 03:31 PM
