Sponsored by: CARiD
2003 discovery electrical noise
Old Oct 17, 2010 | 10:34 PM
mara9205's Avatar
4wd High
Question 2003 discovery electrical noise
my 2003 lr discovery is having what it seems an electrical or high pitch noise coming from the left driver side dashboard please help?
Old Oct 18, 2010 | 08:23 AM
The only thing that will make noise from the drivers side of the dash is the small fan that samples air to regulate the a/c temp.
Old Oct 18, 2010 | 08:35 AM
hilltoppersx's Avatar
whats the mileage on your truck? are you sure its from inside the truck and not from under the hood in that direction? is your CEL on? when was the last time you checked your PS fluid?
Old Oct 18, 2010 | 12:24 PM
mara9205's Avatar
4wd High
Default electric noise
the lr has only 77,000 miles on. the head gaskets and other gaskets been replaced. the oil is been changed, the air conditioner has a new motor, the brake pad and rotor been replaced, everything done this past month by landrover and another qualified technician. But as soon as they fixed everything the passenger front door lock is not opening and the noise inside the dash on the left driver side started. It sounds like electric wave or noise. I replaced the battery for my opener and it seems that it has something to do with that because the remote control is not activating . another words sometimes makes connection and others dont. Please tell me what u think .
Old Oct 18, 2010 | 02:45 PM
if its just the one lock that is not opening then it is the actuator. if you hit the unlock button twice do the other 4 locks unlock?
Old Oct 18, 2010 | 06:15 PM
mara9205's Avatar
4wd High
yes, with the door i was told by lr its the actuator, sometimes the rest of the doors open but other times the opener and the truck dont contact with each other and the light for the opener does not even light up and it has a new battery in it. but the sound coming from the dash board in the drivers side is what i am concerned about.
can you help me. Thank you
Old Oct 18, 2010 | 08:18 PM
lordmorpheus's Avatar
When I read your post this morning, the first thing I thought of was the fan for the inside air temperature sensor. To the left of where your steering column goes into the dash, there is a small square box with fins cut into it (about 1" x 1"). Is the noise coming from there? Take a piece of flexible hose, with one end in your ear to use as a stethoscope to help determine from where the noise is coming.
Old Oct 19, 2010 | 12:34 PM
mara9205's Avatar
4wd High
Cool electrical noise
thank you for your recommendation about the electrical noise,i'll check on it, but what you think could be the problem with the remote control that sometimes open the truck and makes a noise like if an electric antenna is closing down, someothers is like is no contact and the light from the remote dont even come on.
Old Oct 22, 2010 | 04:48 PM
mara9205's Avatar
4wd High
Thank you Mike it was the fan that regulates the a/c. your awesome.
Externet
Dec 6, 2012 10:17 AM
DiscoStuart
Dec 23, 2011 08:32 AM
Stanleycupgoalie
Jan 25, 2011 08:50 PM
userdmx
Apr 7, 2008 09:25 PM
ajh
Audio/Visual Electronics
Sep 2, 2007 08:01 PM
