Sponsored by: CARiD
2003 Discovery Oil Pump NEED HELP
Old Aug 24, 2011 | 11:26 PM
Rovermike85's Avatar
8th Gear
Default 2003 Discovery Oil Pump NEED HELP
I have a 2003 land rover Discovery HSE i have this huge problem with it want to see if anybody knows whats wrong.... ok so I took it to the local mechanic where they fix Land Rovers BMW etc. they said there is no pressure from the oil pump going up to the engine they put a new one on still doing the same thing what could be wrong with this truck????
Old Aug 25, 2011 | 05:29 AM
Certain D2s have an outboard oil cooler mounted lower front of radiator area, near tranny cooler. From the RAVE manual (cooling section):
Engine oil cooler (Only applicable to vehicles
up to VIN 756821)
Obstructed cooler or oil line to/from would do that, and it certainly can also on a D1 where the cooler is built into the radiator on the right side of the vehicle.
There have been other posts to suggest that it would be possible to bypass the cooler with serious hoses and clamps or adapters, as later models don't have it. If going that route might want to consider jumbo oil filter to gain back some volume of oil.
Old Aug 26, 2011 | 02:38 AM
8th Gear
so you think it needs a jumbo oil filter
Old Aug 26, 2011 | 04:41 AM
Just pointing out that if you bypass a factory oil cooler, if so equipped, you can make up some of the volume lost with a slightly larger filter, I run a WIX that is double the length of the standard filter. But the truck with no oil pressure has other issues to solve before worrying about that. I would suppose that the techs working on the truck may have already swapped filters to eliminate that (most filters have a bypass valve inside and can't obstruct 100%).
Old Aug 26, 2011 | 04:49 AM
There have been posts about the oil pickup tube coming loose and falling off in the oil pan, and pick up being obstructed with gunk, and entire engine being obstructed with small pieces of RTV rubber from over zealous previous mechanics that put on way too much gasket sealant. Hope your problem is much simpler. Are they doing a mechanical pressure test or just depending on the warning light? And how did you come to believe that there was no oil pressure - can't drive very far that way...
Old Aug 27, 2011 | 12:24 AM
socalrovershop's Avatar
are they installing a new front cover or just the oil gears?
Old Aug 27, 2011 | 08:14 AM
Mike, before these idiot mechanics screw up your engine you might want to send me your number so I can walk you thru what they should be doing.
Old Aug 27, 2011 | 10:17 PM
8th Gear
they installed a brand new front cover/oil pump, and they did a mechanical pressure test, and Disco Mike ill send it to you on Monday so you can talk to the Mechanic where i Have it
Old Aug 29, 2011 | 12:46 AM
ive ran into alot of these new covers where the check valve at the oil gears are reversed. just an idea to look at.
Old Aug 29, 2011 | 03:47 AM
ross ben's Avatar
There could be several things wrong... but one is not your oil pump. The oil pump works or it does not work and if it not working you car by now is also not running. You don't state miles on car but sounds like the engine is getting old and tired... in other words the engine is about wore out.
daniep
Sep 18, 2009 05:40 PM
Greg Duncan
Aug 17, 2009 03:26 PM
LRScott
Jun 17, 2008 02:44 PM
Shryan
May 19, 2008 10:57 AM
Chrisinhouston
Feb 10, 2008 07:43 PM
