Sponsored by: CARiD
2004 Discovery lug pattern/ trailer hubs to match?
Old Jul 15, 2009 | 05:32 PM
NWDiscoRover2004's Avatar
Default 2004 Discovery lug pattern/ trailer hubs to match?
Hello, I'm in the middle of fabricating an overland trailer to pair up to my 2004 Land Rover Disco. I'm stopped by the lug pattern and trying to locate a bolt pattern on trailer brake drums to match.
The local tire shop told me today that my Rover has a 5 on 120mm bolt pattern. He said I would not be able to find brake drums with a pattern to match this.
I want my trailer tires/ wheels to be the same as those on the land rover (for compatibility reasons).
Has anyone found a solution to this issue? Can I have drums redilled? Adapter available?
Thank you,
Curtis
(406) 581-9507
curtpb@hotmail.com
Old Jul 15, 2009 | 06:29 PM
reddevildemo's Avatar
Look for a wrecked Rover and use the axle?
Old Jul 15, 2009 | 08:30 PM
If you get a chance, go on the LRRFourms and look at the picture of a newly built trailor.
Old Jul 16, 2009 | 08:38 AM
antichrist's Avatar
Your sig says you have NATO wheels, so I'm assuming you're running some sort of adaptor since NATO wheels are the Series Land Rover/Defender/D1 bolt pattern. Just get a couple of D1 stub axles and hubs, then you can run NATO's on the tailer as well.
gruehle
Jul 27, 2020 09:10 AM
ek5usmc
Sep 17, 2008 04:49 PM
vernmangk
LR2
Aug 22, 2008 03:32 PM
cory360
Mar 7, 2008 06:55 PM
LRDISCO
Nov 23, 2007 08:20 AM
