Sponsored by: CARiD
2004 Discovery Service Engine Light VS Check Engine
Old Feb 1, 2017 | 07:05 AM
oneblessedmess's Avatar
7th Gear
Default 2004 Discovery Service Engine Light VS Check Engine
Hey there, I promise I tried searching the internet before asking this but I feel like I get conflicted information. This morning my "Service Engine Soon" light came on. It was a steady light as opposed to a blinking/flashing light (which I understand means don't drive etc).
I'm confused because I've read that it is simply a "service" light for regular maintenance things like oil etc. Some have said there is a Service light and an actual CHECK ENGINE light and they are 2 different lights/indicators. If so where would the check engine light appear?
I know I probably do need to have it checked at Autozone or some place but I was just looking for clarification on the Service Engine Soon/Check Engine light issue.
Can anyone help a girl out?
Old Feb 1, 2017 | 07:18 AM
LR Techniker's Avatar
"SERVICE ENGINE SOON" is the same as "CHECK ENGINE". Different manufacturers use different indicators. Some even use a symbol of an engine. They all indicate that an emissions failure has been identified. And you are correct, if its flashing, its best not to drive.
Many Land Rovers do have a separate warning for "service", but it is usually a message on the display that says "Service Due" or "Service Now", however the Discovery II has no such message.
Old Feb 1, 2017 | 07:30 AM
7th Gear
Thank you for clarifying that!! I'm anxious to find out the issue. The pesky 3 amigo lights have been coming on and off lately wondering if they play a part.
Old Feb 1, 2017 | 01:10 PM
7th Gear
Ok so I just ran home which is a 1 mile round trip and the temp gauge is going up but that light isn't flashing. I'm so confused
Old Feb 1, 2017 | 02:21 PM
Robert Booth's Avatar
If thr temperature gauge needle moves beyond halfway on the gauge, your engine is overheating.
If that's happening, don't drive it. Let it cool off. Check the coolant level.
you really do need to read the check engine codes to see what's going on with the car. It's also critical to know what the engine operating temperature is.
FlyingZebra34
Feb 22, 2014 05:39 PM
sayeedA
Nov 22, 2011 10:49 AM
osulax43
Jul 21, 2009 08:34 AM
osulax43
Jul 16, 2009 09:56 PM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
