Sponsored by: CARiD
2004 RR Steering Hard after radiator hose came off.
Old Mar 24, 2012 | 08:02 AM
Young's Avatar
Default 2004 RR Steering Hard after radiator hose came off.
The lower hose on my radiator came off about a week ago and it was towed to the dealer where it was replaced. However the truck began making this whistling noise periodically and just recently the steering has become hard as if it has no power steering... When you initially start the vehicle the steering works fine until you out it in gear and then it becomes difficult to turn. Any suggestions?
Old Mar 24, 2012 | 08:35 AM
So, what have you checked so far??? Have you checked your fluid level, if low again, you still have a leak, if not low then most likely the pump has failed.
Old Mar 24, 2012 | 04:19 PM
Young's Avatar
I've checked the fluid and all seem well....if the pump has failed would it allow the steerimg to work on a cold start and then fail.... I read somewhere about a servo valve?
Old Mar 24, 2012 | 06:40 PM
Was the belt doused with coolant?
If so it may need to be replaced, it will slip and you will not have any power steering or the like.
johnnyjohnny
Sep 26, 2019 09:37 PM
D2 2003
Nov 7, 2017 07:41 AM
cruzer555
Jan 11, 2014 07:15 PM
dapo
Apr 25, 2009 01:22 PM
