Sponsored by: CARiD
2005 LR3 White smoke only briefly at startup- no other symptoms?!
Old Jul 27, 2018 | 03:34 AM
The Deputy's Avatar
I'd be leaning towards an injector nozzle leaking/dripping down, while not running, if you are getting white smoke at start up...and it goes away once running for a bit. I'd be smelling for unburned fuel on start up.
Brian.
Old Mar 6, 2021 | 02:16 PM
BigZ's Avatar
6th Gear
'06 LR3 175k miles 4.4L Same issue for me, occasional white/blue smoke at startup and spark knock. Took out the injectors and had them serviced at a local specialist. 25 bucks a piece. 2 were totally stuck open the others failed spray tests. 175k miles. Put in new plugs NGK plugs too plus oil change. Seemed to be more responsive and running really good. Mileage got worse and a week later, smoke on startup again. I have changed the pcv and cleaned the EGR valve and intake. Also, cleaned the MAF. Not wanting to fork out $300 for the EGR valve. See what happens. Everything else is tight, runs really good.
Old Apr 1, 2021 | 06:49 AM
BigZ's Avatar
6th Gear
Follow Up- Still getting intermittent smoke at startup. Doesn't matter if its a cold start or warm after driving. I also cleaned the MAP sensor at the back of the manifold. Total pain to get reach. If pulling the MAP plan on using a mirror. After everything in the fuel/air system checking out I am now leaning toward thinking I have worn valve seals. Will prob pull the valve covers and inspect.
norman.j.s
May 6, 2022 09:15 PM
twin6
Feb 19, 2017 02:16 PM
mirepoixmatt
Dec 16, 2013 10:30 PM
LR3Beast
May 29, 2013 06:45 PM
jwmstang
Apr 12, 2007 10:31 PM
