Sponsored by: CARiD
2006 to 2010 Headlight Conversion Wiring Help PLEASE!!!
Old Jun 5, 2010 | 12:27 AM
RWDRIFT's Avatar
4th Gear
Default 2006 to 2010 Headlight Conversion Wiring Help PLEASE!!!
Ok I was trying to finish up the 2010 conversion before I take the truck into the body shop for paint and installation of the Overfinch body kit and I am still having some problems with the wire diagrams. I was actually able to get a 2010 front headlight wiring diagram and a 2006 headlight wiring diagram. I think I am still doing something wrong, because after wiring up the headlights I still have a few issues. I tried to follow the instructions on l322.com but his car is a 2002 and not a 2006 which has adapted headlights.
THINGS THAT WORK
Xenon Low Beam
Halogen High Beam
Turn Signals
THINGS THAT DONT WORK
adaptive headlights
angel eye and side marker flicker when xenons are turned on
headlight error on dash indicator light.
I pretty much need anyone who has finished the conversion to let me know which pins I am connecting that are messed up. I am assuming once I get the wires correct, the angle eyes and side markers won't flicker, the adaptive headlights will work, and I will have no error lights on my dashboard.
PROBLEMS!!!
Right now I have an headlight error on my dashboard. I can't get the adaptive lights to flash up and down when the cars starts. The angel eyes and side marker flicker when the xenon are turned on. They work fine when in parking lamp mode only.
The 2010 headlight plug has missing pins on 5,6,7,8.
So there is only 12 pins to connect up.
I also had a questions about pin 8 on the 2006 headlight. It looks like pin 8 and pin 13 on the 2006 wire diagram are connected to the trucks canbus system. Problem is there is no pin on the 2010 modules for this. I am almost there. Just need a little help.
Here are the wiring pins for the 2006 and 2010 headlights.
Old Jun 6, 2010 | 09:25 AM
ibis1's Avatar
Talking 2010 Headlamps
RWDRIFT,
I don't know if there are any "conversion kits" available or not, but without such a kit it would be almost impossible to have the 2010 headlamps function correctly. The 2010's (AFS or Bi-Xenon) are controlled through the CJB, which your vehicle does not have and they also have additional modules (AFS) You may be able to get some partial function as it appears you have, but full operation is not feasible, unless someone has come up with a kit to bypass the needed components. ibis1
Old Feb 13, 2011 | 07:36 AM
sc range 2008's Avatar
did u ever figure out the wiring problems? I have a 2008 sc range rover and did the conversion with the same problems with headlights. Please let me know!!!!! thx
adamsrotors
Sep 28, 2019 12:08 PM
davepl
Feb 2, 2015 10:40 PM
RWDRIFT
Mar 11, 2010 01:46 AM
moocowman
Jan 3, 2010 05:33 AM
Street Wolf
Nov 17, 2008 01:56 AM
