Sponsored by: CARiD
2012 LR4 check engine light
Old Sep 14, 2019 | 12:18 AM
brettusc's Avatar
3rd Gear
Default 2012 LR4 check engine light
My 2012 LR4 has the gas cap warning light coming on intermittently along with the check engine light (constantly on) for the past 4 weeks. I had the DTML valve, charcoal canister and new OEM gas cap installed, cleared the codes but the lights remain on. Also experiencing rough start after filling the tank and have to hit the accelerator to keep the engine running, drop it in drive and vehicle drives fine and starts up with no issue until the next fuel up. Anyone have thoughts on what it could be? Thanks
Old Oct 1, 2019 | 09:44 AM
LR Techniker's Avatar
Purge valve is stuck open. This system pressurizes the fuel tank and lines to check for leaks, when the car is off. It attempts to "seal" the system by closing all the valves and with the purge valve sticking open, that is the leak source.
Also, since the valve hangs open, vapors from the tank during refueling are pushed into the intake manifold and flood the engine, causing the hard/rough start.
Old Oct 1, 2019 | 11:39 PM
brettusc's Avatar
3rd Gear
Correct, I had my independent LR mechanic replace the purge valve assembly, issue has finally been resolved. Thanks for the feedback !
Collin Wickes
Apr 7, 2019 08:13 PM
john_greg
LR4
Nov 7, 2018 01:33 PM
ftsalonga
Jan 18, 2015 12:35 PM
pfcboi
LR4
Jan 9, 2014 01:09 PM
Kingfish
LR4
Jul 5, 2012 08:24 AM
