Sponsored by: CARiD
2013 Evoque not starting
Old Feb 14, 2021 | 08:22 AM
Dilly1966's Avatar
Default 2013 Evoque not starting
Hi.
My wife has an automatic 2013 Evoque.
She went to start it yesterday the headlights flickered, the Speedo needle flickered up and down, and a 'gearbox fault' and 'steering column locked' warning was displayed, and the car wouldn't start. This morning I went out to look at it and noticed the rear red lights were illuminated. Inside none of the dash lights came on and instead there was a ticking/clicking noise from the glovebox and the hazard warning lights button flickered (but the hazard lights weren't on externally). I suspect a battery issue. Using a simple multi meter set at 20 DCV I got a reading of 0.00. I have also read about a small auxillary battery positioned near to the fuses beneath the glove box which can cause similar symptoms apparently?
Any help would be much appreciated.
Old Sep 23, 2021 | 05:01 AM
Dave Copley's Avatar
Default Did you sort this
I have identical symptoms. Did you sort it please , I’m hoping it’s just the battery
Old Sep 23, 2021 | 05:16 AM
Dilly1966's Avatar
Yep, just replaced the battery myself and all fine.
Old Sep 23, 2021 | 05:34 AM
Default Thanks
Much appreciated
DiscoDynomite
Jan 16, 2020 09:56 AM
metzdmichael
Oct 11, 2019 04:41 PM
bikeG976
Nov 28, 2010 12:32 PM
Millchil
Apr 9, 2008 08:54 PM
XBlade
Feb 26, 2007 10:49 AM
