Sponsored by: CARiD
3 amigos go off when towing heavy weight?/with codes from ABS Amigo
Old Sep 25, 2010 | 08:06 PM
X53Gunner's Avatar
Default 3 amigos go off when towing heavy weight?/with codes from ABS Amigo
Ok guys and gals. I have had the 3 amigos problem since I have bought the Land Rover its a 2002. I have found when I hook up my car trailer and load it up that the amigos seem to go off and stay off. Until I unhook the trailer and start it back up they come back on. I did get one of the testers that reset and give you the codes. It doesn't want to reset it but here are the codes I was hoping along with the codes and the towing with wieght thing you guys might be able to narow my problem down and let me know what to look for and at first. Thanks for the help!
Scott
--ABS Amigo Box V1 RSW Solutions LLC Copyright 2010-----
|* The information provided is without warranty of any kind.*|
|* IN NO EVENT SHALL RSW Solutions BE LIABLE FOR ANY LOSS OR*|
|* INJURY OR DAMAGES resulting from or connected to use of *|
|* this Information or Product. YOU HEREBY WAIVE ANY AND ALL*|
|* CLAIMS AGAINST RSW Solutions ARISING OUT OF YOUR USE OF *|
|* THIS INFORMATION OR PRODUCT. *|
1.--Current Faults---->
Active Faults:
114:Shuttle Valve Electric Failure
Logged Faults:
<-END Faults
..--Previous Faults--->
Active Faults:
022:ECU Gnd or Reference Gnd bad
064:Front Right sensor electric fail
065:Rear Left sensor electric fail
066:Front Left sensor electric fail
067:Rear Right sensor electric fail
Logged Faults:
None
<-END Faults
Active Faults:
Comms Error
Logged Faults:
Comms Error
<-END Faults
Old Sep 26, 2010 | 07:40 AM
Who wired your trailer harness and is it a factory conversion or an aftermarket on?
Old Sep 26, 2010 | 08:59 AM
X53Gunner's Avatar
Wish I new the answer Mike, To me it looks like someone else and not the factory would have done it. It is the 4 prong style and it hangs quit a ways down from the vehicle just doesn't look like a quality factory job to me. I didn't think that would have anything to do with it but I'm all ears. If it helps they don't seem to go out everytime just when loaded heavy. Or a couple cycles of turing the key on and off when loaded with a heavy trailer they seem to go out. When the trailer is disconected somtimes they will stay out for a couple of times out and about then just pop back on. Hope this didn't confuse you. Thanks!
Scott
Alex_M
Mar 29, 2020 05:33 PM
Blakesrover
Feb 20, 2013 10:31 PM
outback96
Feb 1, 2010 10:55 PM
yuenie
Jan 13, 2010 05:37 PM
Princess
Jul 4, 2009 12:24 PM
