Sponsored by: CARiD
'52 Disco Brake Issue
Old Jan 19, 2017 | 02:39 AM
Dubgrrl's Avatar
Default '52 Disco Brake Issue
Hi all - new member here, I'll post an intro soon but if anyone could help with the below
- I have a 52 plate diesel discovery and this morning the brake pedal goes completely to the floor and the handbrake light stays on even though it's not! I drove just round the corner to test it and it does stop but with no urgency and certainly not safe at the moment.
can anyone suggest anything that may be causing this please ??
Old Jan 19, 2017 | 09:34 PM
XCELLER8's Avatar
get under the vehicle and/ or jack it up and remove the wheels to first check for a broken or leaking brake line or caliper. It could also be a faulty master cylinder, but check on the leaks first........
Old Jan 20, 2017 | 07:42 PM
Matthew Desormeaux's Avatar
Happened to me turned out the rear driver side caliper was cracked in half
Old Jan 22, 2017 | 06:07 PM
LR Techniker's Avatar
The park brake light is ALSO the "low brake fluid" light. Check the fluid level in the reservoir (master cylinder), I bet it is low, which is why the brakes feel the way they do, there is air in the system. You will need to find the leak, repair, fill and bleed the heck out of it, to get the brake pedal feel back.
tunernewb92
Oct 20, 2009 07:15 PM
cello
Oct 13, 2008 07:55 PM
clemson rover
Feb 29, 2008 12:27 AM
fitch11
Dec 29, 2007 05:07 AM
