Sponsored by: CARiD
89 Rover Sputtering HELP
Old Oct 21, 2007 | 09:09 PM
elkhutr's Avatar
5th Gear
Default 89 Rover Sputtering HELP
Was driving and all of a sudden my EFI light comes on and it started cutting out like it was flooding, until you floor it it goes fine.
The motor cuts out and will back firesometimes threw the air filter, the only way it will get going or keep moving is to floor it.
It ideals for awhile then it will die, but starts fine.
Thanks
Old Oct 21, 2007 | 09:48 PM
ajh's Avatar
ajh
Default RE: 89 Rover Sputtering HELP
Fuel filter/pump? or water in fuel? Try adding some gasline antifreeze and changing the filter first.
Old Oct 21, 2007 | 10:22 PM
elkhutr's Avatar
5th Gear
Will try the gasline antifreeze and filter and let you know.
Thanks
Old Oct 22, 2007 | 08:04 AM
Before you start adding parts or fluids, how many miles on your truck and what sort of tune related work has been done on it recently?
Old Oct 22, 2007 | 10:05 AM
ajh's Avatar
ajh
If he hasn't done a filter on an 89 it's going to need it, and removing any built up condensation is a good idea anyway.
Remember if you're running premium fuel you're not getting the advantages of the 10% ethanol in the blend to remove any water build up.
So neither can hurt, and should be done from time to time anyway.
Old Oct 22, 2007 | 11:07 AM
elkhutr's Avatar
5th Gear
80,000 miles I've had it about 3 months I put new plugs in it thats it, since I had it. I doubt the person I bought it from did much to it. I'm running the cheap fuel. Also the tank of gas before this one I put FI cleaner in the tank... Could have that done something?
Thanks
Old Oct 22, 2007 | 11:35 AM
So first of all, no cheap gas, it will just carbon up your heads and cost you big repairs.
Second, what brand of spark plug and did you check the gap?
You will probably nee to replace the plug wires, I would suggest you install some Magnacor 8mm wires, Rovers run real well on them.
I would agree with the last post, change your fuel sytem.
Old Oct 27, 2007 | 05:25 PM
elkhutr's Avatar
5th Gear
I tried the antifreeze in the gas and a new fuel filter. It's still doing the same thing, just noticed when the engine is cold it runs fine the EFI light is still on.
Old Oct 28, 2007 | 08:38 AM
Call me today and lets talk about this.
303-862-7680
Colorado between 7 am and 8 pm
knucklzluvsrovers
Mar 10, 2011 09:07 PM
Rover9
Feb 23, 2007 04:34 PM
Charlie L
Jan 7, 2006 10:26 AM
Charlie L
Dec 8, 2005 02:41 PM
JA-NH
Jan 22, 2005 08:32 AM
