Sponsored by: CARiD
96 4.0 disco runs rich burns through alot of fuel
Old Jul 27, 2012 | 08:14 PM
  #21
Originally Posted by cbr929rroo
As far as the cats go, what is some input on universal cats? I have never had any problems with them on other vehicles but it seems my disco is a bit stubborn with some brand parts.
Yes you can use universal's.
Old Jul 28, 2012 | 02:29 PM
  #22
cbr929rroo's Avatar
ok time for an update. i cleaned the ecu and wire harness, cleaned maf. truck seems to be running better. still drops speed going up hill and cel came on and then shut right off still coming up o2 sensor i guess i will replace that. idle still drops low enough to make oil light flash but that also is just once in a while. now i have to replace the pressure hose on power steering just sprung a leak. it seems to never end . oh forgot to mention the other night it was very cool out and truck ran even better.
Old Jul 28, 2012 | 10:27 PM
  #23
Scharfire's Avatar
you should see a huge difference once you change out that o2 sensor.
Old Aug 4, 2012 | 04:41 PM
  #24
cbr929rroo's Avatar
Unhappy
Sorry its been a while. But here we go again. Once truck has been driven for some time it starts acting out again. Seems like no power when stepping on gas I mean some times it won't even get out of its own way. I also noticed today that the shifter inside the truck gets very hot to where you can not touch the metal shaft going down through the floor. Trans service was done about 3000 miles ago. And yes ceo only shows o2 sensor which I picked up today and will replace tomorrow. I also noticed the fuel pump kept running even after I shut the truck off and removed the key.
Old Aug 4, 2012 | 05:45 PM
  #25
Gear shift level getting hot is a electrical ground issue, there is a ground strap under the truck in that area, it will start a fire and burn the truck to the ground.
Old Aug 4, 2012 | 06:04 PM
  #26
cbr929rroo's Avatar
So then do you suggest I put another ground on the truck? If so in same location or any where on the trans.
antiteck
Jan 2, 2013 10:42 AM
antiteck
Dec 18, 2012 11:23 AM
RoverLady
Apr 26, 2012 08:56 PM
VikingDiesel
Apr 27, 2008 02:45 PM
bboat567
Aug 2, 2005 12:19 AM
