Sponsored by: CARiD
96 D1 valve job, now no spark????
Old Aug 14, 2006 | 09:58 PM
TIMO's Avatar
7th Gear
Default 96 D1 valve job, now no spark????
I just put it all back together after a valve job and now I'm not getting spark. All connections have been made, I'm getting good fuel pressure at the rail. I did not touch the crank or cam shaft sensors or connectors. ANY IDEAS???????????? Tim O.
Old Aug 14, 2006 | 11:52 PM
Bait's Avatar
Default RE: 96 D1 valve job, now no spark????
Welcome Timo!
First of all, your signature suggests you are from The States, AKA, USA. Secondly, a NAS 1996 Discovery is a DII not a DI. It makes a big difference. A 96' DII uses the GEMS engine management system which is distributor less.
Give us a little more info and we can help you out. Why the valve job? The crank sensor connector is connected to the drivers side rear head. It would have to be disconnected in order for the head to be removed on a DII.
Cheers
Old Aug 15, 2006 | 10:34 PM
TIMO's Avatar
7th Gear
Valve job was done due to major miss firing.and poor compression due to valves not sealing... Only a couple valves were sealing...Anyway I found that the crank sensor, came unplugged inside the guard...So its good to go.. I'm new to the site and only had the Rover a month sorry about the DI ...DII stuff...First Rover... WAS A JEEP GUY..............Tim
Old Aug 15, 2006 | 11:56 PM
Bait's Avatar
No worries. Glad you you got her running
Old Aug 16, 2006 | 11:13 AM
ORIGINAL: Bait
Welcome Timo!
Cheers
Bait,
Don't yo have it turned around, a 96 is a D1 not a D2.
Mike
Old Aug 17, 2006 | 10:32 PM
Bait's Avatar
ORIGINAL: Disco Mike
ORIGINAL: Bait
Welcome Timo!
Cheers
Bait,
Mike
Yep! Thanks for the correction Mike. Guess I was thinking RR, duh...
Old Aug 18, 2006 | 10:07 AM
ORIGINAL: Bait
ORIGINAL: Bait
Welcome Timo!
Cheers
Bait,
Mike
Bait,
What do you think about a bad crank sensor on this truck?
Mike
Old Aug 20, 2006 | 03:04 PM
TIMO's Avatar
7th Gear
SO it is a D1 correct????? The crank sensor isnt bad on mine but the connector some how is messed up and it came unplugged probably while moving around the wiring harness...So I fixed up the connector so it wont pop off on its own, and she fired right up.. Thanks for the suggestions...............Tim
Old Aug 20, 2006 | 04:53 PM
ORIGINAL: TIMO
COOOL!!
Mike
Torancis_LR
Jul 10, 2009 11:27 PM
egreenbuilt
Apr 10, 2008 08:16 PM
BURover
Aug 30, 2006 03:06 PM
LandRoverXD
Mar 5, 2006 02:46 PM
fsufan8
Aug 5, 2005 03:48 PM
