Sponsored by: CARiD
96 Discovery extended cranking time and rich fuel smell
Old Mar 11, 2010 | 09:58 AM
alcing's Avatar
3rd Gear
Default 96 Discovery extended cranking time and rich fuel smell
Hi all,
I have a 1996 Discovery that just recently got a problem starting. You have to crank for about 10-15 seconds before it will start and then you can smell it running rich.
Had a code 1187 for O2 sensor. Bank 2 wasn't responding during monitor tests. Replaced both upstream sensor but don't have tool to reset code. But don't think that could have effected starting since computer shouldn't be looking at O2 sensors during starting.
Is there a cold start injector?
Old Mar 17, 2010 | 09:06 AM
alcing's Avatar
3rd Gear
Bueller, bueller?
Old Mar 18, 2010 | 05:59 AM
Rovin4life's Avatar
check fuel pressure to see what is going on. and check compression
Old Mar 19, 2010 | 08:54 AM
alcing's Avatar
3rd Gear
I haven't erased the code and reset the computer because my scanner doesn't have software for European cars.
My friend said that vehicle won't run right until computer is reset, is that true???
Is it possible to reset computer without a scanner??? i tried disconnecting the battery but that didn't work.
Old Mar 20, 2010 | 11:30 AM
Rovin4life's Avatar
yes it will clear the code but the oxygen sensor won't be causing the issue. hard starts are fuel or ignition or compression issues.
russburcham
Apr 14, 2013 12:11 PM
cbr929rroo
Aug 4, 2012 06:04 PM
southerno1
Feb 20, 2009 08:13 AM
markroll
Mar 19, 2008 10:04 PM
albertbc
Mar 8, 2007 12:29 AM
