96 discovery passenger side window doesnt open
Hi. I'm wondering if anybody can help me.
I have a 96 Disco with 110,000 miles. My passenger side window just stopped working. All other windows are working. I've swapped the switches with the other windows and that does not work. Fuses seem fine too.
Could this be a connection problem within the door? If so how do I get the door panels off? I tried to pull it off, but heard a "crack" so I did not pull further.
Thanks for any help.
Hatanhi
Hatanhi
Is the window motor working, making a noise? You most likely have a bad window regulator which will not all the window to roll up. Check and make sure you have power to the window regulator and if so replace it.
Mike
Mike
If the motor is quiet don't worry about the regulator. Get a test probe and starting check for power to the switch and the window motor.
Mike
Mike
Marni
Sep 15, 2011 10:03 AM
bcolins
Oct 2, 2008 12:36 PM
marlymarl
Jul 28, 2005 12:23 AM
